DRAW: How to show comment text in print
I am generating a PDF of a drawing from LibreOffice draw. How can I print the contents of the Comment boxes?
Here is a link to the file for reference:
Pre-CampaignTimeline.odg (180.3 KB)
You can use the upward pointing arrow icon to upload files to this site.
Using a third party site can reduce interest in your question. Cheers, Al
Removed link and uploaded file. Thank you
Export as PDF, and in the PDF reader (tested with the Adobe’s one), you can view and export the comments.
I am not seeing the comments. Navigating to View > Tools > Comments displays the comment frame but it appears empty. I am using Adobe Acrobat Reader Dc Verison 2021.007.20099
Is there an option I need when exporting to PDF from DRAW?
Tick the box Comments as PDF annotations
Export to PDF:
Cheers, Al
…and print.
Excuse me that the screenshot is in Spanish.
THANK YOU!! This is exactly what I needed!
