I’m using LibraOffice Calc. Version: 6.3.3.2 Windows 10
Suddenly a red highlight around the frame of the cell has appeared when I paste info in Calc.
Followed by a red line across the page.
What is it?
How can I turn it off?
What is it?
Btw, your question head line does not match your question at all…
You activated Change Tracking, probably by accidentally hitting Shift+Ctrl+C, disable with Shift+Ctrl+C again or menu Edit → Track Changes… → uncheck Record.
