When editing “complex” documents (adding index entries make a document “complex” for this question), always work with View>Formattings Marks and View>Field Shadings enabled so that you can see where hidden formatting/markup is located.
Indexed words have a light gray background. Hover your mouse over it. A tooltip appears displaying the index entry. Right-click and Index Entry to edit.
Warning! If spelling checker is active and the word under the shading is underlined with a red wavy line (denoting a spelling error), the pop-up menu does not offer Index Entry. So, fix the spelling mistake first or disable spell check.
The Edit Index Entry dialog allows you to modify your entry. You can also navigate from entry to entry (without the need to hunt for them) with the solid black arrows above the buttons.
Thanks to the navigation arrows, it does not real matter which index entry you select to begin reviewing your document.
