All edits I have made today have highlighted the cells in red and I cant select all the data and sort it
What have I turned on
I cant go back to a previous version
First of all, turn off Record - press Ctrl+Shift+C or select from the menu:
Remember that Ctrl+Shift+C enables this mode and be careful with this hotkey. Or just remove this hotkey:
Thank you very much
and what a swift response
I am extremely indebted to you
Regards
Stuart
The way is add a comment not use answer. Please, if the answer solves the question click
