I don’t know if this is the right forum for this technical question. If not, ill appreciate any hint to the right one.
I am trying to use LibreOffice as Ole-Server to embed an instance in my application using the Programming Language Delphi and the OleBridge. I have tested that with 32Bit LibreOffice in my 32Bit Application so far and this works as expected.
Now i also like to use LibreOffice in 64Bit Application - therefore i tested it with 32Bit LibreOffice as well as with 64Bit LibreOffice. The results are the following:
- 32Bit LibreOffice: fails upon Object Creation with
Class not registered.
- 64Bit LibreOffice: fails upon Object Activation (using DoVerb, for more information: https://msdn.microsoft.com/en-us/library/windows/desktop/ms694508(v=vs.85).aspx): LibreOffice shows the Document Recovery Window, then immediatly crashes. After that the application itself fails with
The remote procedure call failed.
For 32Bit, it seems that this wont work at all, so i focused on using 64Bit. I tried different parameters for LibreOffice: With ‘–norestore’, Document Recovery Window is not shown, but the problem still persists. Other parameters have no effect.
Is there any way to fix that? Or is this a general problem of LibreOffice?
I am using Windows 10 (64Bit).
