This macro is with Autocalculate and progressbar, because export 500 files is very slow
Don’t forget to uncheck File/ Export as PDF → General/ View PDF after export, because it is very slow if the exported files as shown in PDF viewer
Set constant cmax to 500
Sub exportAsPDFwithFilename
on local error goto bug
const cmax=50 'maximum in your loop
dim oDoc as object, oDescriptor as object, document as object, dispatcher as object, oSheets as object, oSheet0 as object, filename$, i%, oCell as object, sUrl$, a&, min&, max&
dim oDlg as object, oPrubeh as object, oButton as object, iStep& 'variables for progressbar
rem get access to the document
oDoc=ThisComponent
document=oDoc.CurrentController.Frame
dispatcher=createUnoService("com.sun.star.frame.DispatchHelper")
oSheets=ThisComponent.getSheets()
oSheet0=oSheets.getByIndex(0)
rem autocalculation
oDoc.enableAutomaticCalculation(true) 'set automatic calculation
oDoc.CurrentController.ComponentWindow.Visible=false 'hide the window with sheets (maybe it will be faster)
dim args1(1) as new com.sun.star.beans.PropertyValue
args1(0).Name="URL"
args1(1).Name="FilterName" : args1(1).Value="calc_pdf_Export"
oCell=oSheet0.getCellRangeByName("A1")
min=oCell.Value 'initial value in A1
max=min-1+cmax
rem progressbar init
oDlg=progressBarInit(min, max, oDoc) 'show the progressbar
oDlg.Title=min & "/" & max
oPrubeh=oDlg.getControl("Pprogress")
oButton=oDlg.getControl("Pbutton")
for i=min to max
filename=oSheet0.getCellRangeByName("A3").getString() 'name of the file
rem prepare fo PDF
sUrl="file:///home/user/Desktop/New" & filename
if FileExists(sUrl) then 'if file exists you can delete one
'if msgbox("File " & sUrl & " exists" & chr(13) & "Delete one?", 52)=6 then kill(sUrl) 'delete old PDF with confirmation msgbox
kill(sUrl) 'delete old PDF automatically
end if
args1(0).Value=sUrl
dispatcher.executeDispatch(document, ".uno:ExportDirectToPDF", "", 0, args1() )
rem increase value in A1
if i<max then 'increase only if it isn't last value in loop
oCell.Value=oCell.Value+1 'increase a Value in A1
end if
rem update progressbar
iStep=iStep+1
if iStep=10 then 'update progressbar after some steps
oPrubeh.Value=i
oDlg.Title=i & "/" & max
iStep=0
end if
if oButton.Model.State=1 then 'test if Cancel was pressed
bCancel=true
exit for
end if
next i
bug:
if NOT isNull(oDlg) then oDlg.dispose() 'dispose the progressbar
oDoc.CurrentController.ComponentWindow.Visible=true 'show the window with sheets
rem UKAZATEL PRŮBĚHU - zobrazuje se ve středu okna Libre
Function progressBarInit(min&, max&, optional oDoc as object) as object 'vrátí objekt dialogového okna; při chybějícím oDoc ho přichytí k Desktopu
on local error goto chyba
dim oDlg as object, oDlgModel as object, oButtonModel as object, oProgress as object, oWindow as Object
dim oSize as object, oSiz as new com.sun.star.awt.Size, koef as double
const iDlgWidth=140, iDlgHeight=45 'bacha, nejde o pixely jako kdyby se vytvářelo dialogové okno v Basic editoru a pak volalo; dále je pro vystředění okna použita metoda convertSizeToPixel a nastavena proměnná koef
rem model dialogového okna
oDlgModel=CreateUnoService("com.sun.star.awt.UnoControlDialogModel")
with oDlgModel
.Width=iDlgWidth
.Height=iDlgHeight
end with
rem ukazatel průběhu
oProgress=oDlgModel.createInstance("com.sun.star.awt.UnoControlProgressBarModel") 'objekt ukazatele průběhu
with oProgress
.Name="Pprogress" 'jméno pro makro
.ProgressValueMin=min 'minimum
.ProgressValueMax=max 'maximum
.ProgressValue=0 'aktuální hodnota
.Width=120
.Height=15
.positionX=10
.positionY=5
.Border=3 'rámeček
end with
oDlgModel.insertByName("Pprogress", oProgress) 'přidat do modelu
rem tlačítko Zrušit
oButtonModel=oDlgModel.createInstance("com.sun.star.awt.UnoControlButtonModel")
with oButtonModel
.Name="Pbutton"
.Width=40
.Height=15
.PositionX=50
.PositionY=25
.Label="Zrušit"
.PushButtonType=com.sun.star.awt.PushButtonType.STANDARD
.TabIndex=0
.Toggle=true 'aktivace detekce vlastnosti State tlačítka
end with
oDlgModel.insertByName("Pbutton", oButtonModel)
rem vykreslení dialogového okna
oDlg=CreateUnoService("com.sun.star.awt.UnoControlDialog") 'dialog
oDlg.visible=false 'skrýt dialog ať neproblikává
oDlg.setModel(oDlgModel) 'nastavit model dialogovému oknu
rem přidat dialogové okno k oknu dokumentu nebo Desktopu
oWindow=CreateUnoService("com.sun.star.awt.Toolkit") 'dialogové okno
if isMissing(oDoc) then 'přidat k Desktopu - pozor, systém může po chvíli vypsat že program neodpovídá
oDlg.createPeer(oWindow,null)
else 'přidat okno k oDoc
dim oToolkit as object
oToolkit=oDoc.currentController.frame.containerWindow
oDlg.createPeer(oWindow,oToolkit) 'spojení
end if
rem propočty na vystředění dialogového okna
with oSiz 'rozměr z kterého budu přepočítávat koeficient pro usazení dialogového okna průběhu doprostřed
.Width=iDlgWidth
.Height=iDlgHeight
end with
koef=iDlgWidth / oDlg.convertSizeToPixel(oSiz, com.sun.star.util.MeasureUnit.APPFONT).Width 'koeficient pro korekci dialogového okna
oSize=oDoc.CurrentController.Frame.ContainerWindow.GetPosSize 'rozměry okna Calcu
with oDlgModel
.positionX=fix(koef*(oSize.Width-iDlgWidth/koef)/2) 'pozice X od levého horního rohu okna; šířku dialogu je třeba brát zvětšenou koef, pozici X pak zmenšenou koef
.positionY=fix(koef*(oSize.Height-iDlgHeight/koef)/2) 'pozice Y od levého horního rohu okna
end with
oDlg.visible=true 'zobrazit dialog
progressBarInit=oDlg
exit function
chyba:
msgbox("Error " & Err & ": " & Error$ + chr(13) + "Line: " + Erl , 16 ,"progressBarInit")
End Function
