I prefer using LibreOffice Draw since I’m a newbie and it’s easy to navigate, but maybe it’s not the right application for design projects?
Saving it as 300 ppi results in 300 dpi (for good printing) according to the Windows properties, but the dimensions are 2880 x 4320 pixels, while it should be 3000 x 4500?
Really confusing.
UPDATE:
Exporting the image as 119 ppi should result in a file with a resolution of 300 dpi?
When exporting the project as 24x36 inches other software says it’s 9.60x14.40 inches, which is aout 24x36 centimeters.
Do you think that
