There is a planned release of calc with a “filter by color”, as in excel?
I hope not!
@ROST52
Its not a Problem to implement such silly “feature”
The Problem is: Users will use it in there workflow and that is IHMO bad choice on the long run.
I don’t get it… if it’s not a problem to implement such a silly feature, why don’t do it? i work in the stock field of economics, and a “silly” feature like a filter by color, it cost me a macro. A macro, for a filter by color? that’s insane. With excel i can do it with just one click. But i work with linux, and i don’t want to use excel for just some feature that calc doesn’t have for now. For the long run, i think that libre office must simplify things, not make them harder.
@karolus - Why is the usage of the feature in the workflow of users a bad choice in the long run? ---- A conditional formating using background colors could depend on several criteria, thus filtering by color would make it easier.
@ROST52
especially in case of Conditionel Formating its aktually easy to filter by the Condition itself – but it becomes more difficult to determine the CellBackColor which depends on the CF.
Your Example of Usage is one of the Reasons why it will go worse.
