My company’s timesheet software exports XLS files with the old XLS timestamp format (fractional numbers for days since 1900 and fraction of 86400 seconds). Take e.g. 45672,32292, this would be 2025-01-15-07:45:00, but Calc displays and handles it as 07:00:45. I’m using the current LO from Fedora 41 repository.
When I’m trying to manually calculate the correct time I run into rounding problems.
=INT(A1)+TIME(HOUR(A1);SECOND(A1);MINUTE(A1))
$ oocalc --version
LibreOffice 24.8.4.2 480(Build:2)
Sorry, but you show not 45672,32292, but 45672,2921875; and the latter is correctly 2025-01-15 07:00:45.
You are right. Now I’m even more confused.
Seems to be an export bug in our company’s timesheet software.
Thanks!
