I inserted an image to a document, resized it, then placed it where I wanted it but the image is affecting my paragraphs. I have a little section where I had centered text but after placing the image I can’t center it anymore. I can add spaces until I can guess where the center is, but I’d rather not make a guesstimate on it. Can anyone help?? Is there a way to make the image on its own layer so it won’t change my paragraphs?? Thank you!
Right click on the image, go to Wrap, select either Wrap Through or In Background and the image will not affect your text flow.
