So I just downloaded LibreOffice to use for taking notes in class. I always outline while taking notes. I figured out how to outline so that each new subcategory has a new symbol/number in front of it. So when I press enter, the next number header in the sequence appears. Then when I press tab, the next subcategory appears. What settings do I need to change to make enter go back the the previous heading?
For example:
I.Main heading
A. Sub-heading
II. Main heading
