help with formula on conditional formatting with Icons
I am trying to apply conditional formatting to my D column starting at D3 down which is filled numbers. I have numbers in my J column as well (that column does not need conditional formatting).
I would like the D column to have the green smiley when the number in my D column and the number in the J column are less than 512 when added together.
When the D column added with the J column is more that 512 when added I would like it to have the red face applied.
I am not sure if I am on the right track with my formula so any help would be appreciated. Thanks
Add a column with the formula =D3+J3 (fill down), and apply the conditional formatting to these cells; choose value, instead of formula next to the conditions.
If you don’t want to see the results of D+J, see related answer.
Add Answer is reserved for solutions.
Press edit below your question if you want to add more information; also can comment an answer.
Check the mark (Correct answer mark) to the left of the answer that solves your question.
Bravo @LeroyG !
Hello @clos911
The formula you need is the one that provides a figure to test against the content of the tested cell.
Note the comparison sign between the icon and the formula. Very explicit
Try =512-J3 for the orange icon and =512-J3+1 for the red icon. When D3=512-J3 => D3+J3=512, and so on…
UPDATE since your comment :
Yes, apparently, the criteria have to be set for each cell separately. So in D3, provide for a conditional formatting based on the above mentioned formulae. Then, make a second conditional formatting for D4 with the updated formula : =512-J4 for the orange icon and =512-J4+1 for the red icon. And so on.
Be sure to remove the previous conditional formatting by Format>Conditional>Manage, then you select the interesting one, named by its range and you either (delete it and replace it by the 6 ones you need) or you update it by updating its Cell range and create the 5 other ones afterwards. Do not leave several conditional formatting for the same cell : only the first one will be applied.
If you have only 6 cells, this might rapidly be solved.
If this could help, please find herein what I managed to make.
Kind regards, Michel
thank you for the response, unfortunately the formulas did not work for me, all cells had red icons when formulas were inputted…
Hello @clos911
Any success with the updated method ?
If you have a large number of cells concerned by conditional formatting, you may try to develop a macro for this. Have a look at this post.
Thank you, I do have a several cells that I would have this applied to, up to 2000+ rows. I set the conditional format range as D3:D1048576 for the D column…
