Help with newbie SQL syntax error Column not found
I have an HSQLDB database in LibreOffice. It has a table name Clients. I just added a new column to the table named Delivery_Days. It is Text [VARCHAR] with a maximum length of 5 and a default value of MTWTF. It is not the key. I want to set it in all of the existing rows to the literal text “MTWTF” (without the quotes).
I attempt to execute the SQL statement UPDATE “Clients” SET “Delivery_Days” = “MTWTF” and get the error 1: Column not found: MTWTF
I have tried various variations of the DQL statement such as with and without the various quotes.
Question 1: What the heck am I doing wrong? How do I make the value MTWTF be taken as a text literal, not the name of a column?
And question 2, is there definitive documentation for HSQLDB SQL somewhere that would answer this question?
Thanks for your patience with an incredibly naive question.
Charles
Try
UPDATE "Clients" SET "Delivery_Days" = 'MTWTF'
Tables and columns in double quotes, text content in single quotes.
“Delivery_Days” should be a varchar-field. When I see the name I thought it should be something like integer…
Of course that works! Thanks.
Is this sort of thing documented anywhere?
I don’t understand your last sentence. It IS varchar.
Documentation see: Base Guide 7.3
I thought days will be counted, not named like you do. For counting a numeric field is the right field.
Thanks. I do see some examples that use single quotes but I don’t find any formal specification or rule.
Delivery_Days is either of two values, MTWTF or MWF. We currently only offer five-day-per-week deliveries. We are starting to offer the option of Monday-Wednesday-Friday deliveries. I did it this way rather than as a Boolean because I don’t know whether we might offer a third or fourth option in the future.
Thanks again for your help and patience.
Embedded HSQL 1.8 of 2006: Chapter 9. SQL Syntax
