Hidden Section Problem
Dear All,
Please find the attached link
HiddensectionBug.7z - Google Drive.
Dear All,
I have made Database file.
In this file i have created a form.
In this form i have created two section namely GenerateId Section and Library Section.
I have made this sections Hidden.
Even though the section are hidden still some part of section are visible in the upper left hand corner.
I am using LO 5.1
Awaiting for a solution.
Thanks A lot
God Bless U All
The problem is with the use of ‘label’ controls. Instead, use a text box for the label with default text, and not enabled so it cannot be selected.
