It looks like this
When I try to remove it I get the following dialogue:
I’m using libreoffice 5.1.6.2 writer with ubuntu 16.04. Thank you!
It looks like this
First, try upgrading using Ubuntu LibreOffice Packaging team’s PPA. I have fixed some similar problems some time ago - possibly your problem could be fixed,too.
Difficult to say without looking at the real document, but try on Format → Sections if you can “unprotect” it.
Thanks, format → sections had what I needed to remove the section. I’ve also updated using the PPA above.
