How can i insert two different water marks
Hallo.
I need help. I have to use 2 different water marks in a text document. A logo in the middle of the page and address, fone,e-mail at the bottom.
Thank you.
I wouldn’t call these “watermarks” but two “ordinary” objects to insert into the background of the page.
These objects belong to the page style used for this part of the document (I mean you can have several different stationery in your document, each controlled by a page style).
According to your question, I assume you are quite a newbie and presently use only a single page style throughout your document, i.e. Default Style. You can check displaying the style side pane with Styles>Manage Styles or F11. Then click on the fourth small icon in the sidepane toolbar (the one looking like a page). Default Style should be highlighted.
Right-click on Default Style and Modify. Go to Header tab and enable Header on. Do the same for the Footer. Press OK.
Back in your document, click in the header area and Insert>Image for your logo. Select your image and move it with the mouse to the position you like. This can be fine-tuned with Format>Image>Properties, Type tab.
Since the logo is supposed to be a watermark, don’t forget to set its Wrap property to In background otherwise text will flow around it.
The company coordinates are an easier case. Click in the footer and format the information just as you would do in your text. For easier control on placement, I suggest using a table (without borders).
