Thursday, Apr. 28th, 2016. Friends, while using Libre, whenever I try to Paste text into my word processor, I can use the “Paste” icon in the tool bar only one time. After that, if I want to paste that same text in again, or if I want to Copy & Paste in a different text into the same document, I have to use Ctrl-V for each paste after the first one. But Ctrl-V may not allow me to paste in an “unformatted” text. Is there a setting somewhere that allows me to continue to Paste in text using the Toolbar icon, which provides for the selection of formats? Thanks for considering my question.
You failed to mention which version of LO and what operating system you are using.
I have tried to reproduce your situation using both LO v4.4.7.2 & v 5.1.1.3 on a Linux system and have had no success in duplicating the problem. Works each time. Also searched for Bug reports and wasn’t successful ( doesn’t mean one didn’t elude me). However there may be a few things you can try.
Ctl-Shift-v brings up the Paste Special dialog with one of the choices being Unformatted Text. Another choice is Ctl-Alt-Shift-v which is Paste Unformatted Text (This key combination may be changed in Tools->Customize Keyboard tab).
It doesn’t seem to be a clipboard problem since you specify Ctl-v still works. Hope this helps.
