Hello to Grannie Annie from Grandad Alex (nowhere near as alliterative, I’m afraid).
Unless I’m missing something (it’s possible) the place to do this is within the OS (“Operating System”). If, as I suspect, you are working under Windows then it should be possible to do this when saving, since the Save dialog should offer a “Create folder” option. However, let’s assume that you are working from Explorer:
Let’s assume that you are going to have a “Personal” folder in “My Documents” as your top-level folder (a bit of advice: files in My Documents are auto-protected from changes during System Restore, so always store them there). So, create:-
My Documents \ Personal \
Create now as many folders in \Personal\ as you want for the different categories, and store your work in the relevant folder.
One more, extra thing:-
You will want to look at the following options settings:-
(menu):Tools|Options|LibreOffice|Load/Save|General
You probably have already set the Autorecovery period, but I would suggest to also select the Always create a backup copy option as just one extra safety option.
If this helps then please tick the answer (
