How do I create my own color palette for fonts in Writer?
Thanks
Thanks
Colors for fonts are the same as for lines and fillings. The files are in the installation directory in share > palette; those with filename extension soc. Make a copy of such a file and add it with a new name. Open the new file in an editor and set your desired colors and color-names. You can find the color numbers in the dialog, which you get, when you click on “Custom color” in the font color drop-down.
