In Writer, I used to be able to just arrow straight up or down from where the cursor was on any given line. But now, after using the Enter key on any given line above or below, and then using the arrow up or down keys, the cursor jumps to where the Enter key was last used above or below, instead of just going straight up or down from where it actually is on the page.
It’s like the cursor is indenting automatically for no reason just because I used the Enter key on a previous line. Very frustrating.
I am using LibreOffice_4.4.5_Win_x86 as of today.
I didn’t have this problem in any previous version of Writer, so it must be a new default setting. If so, how do I change it so that arrow up and down keys can be used normally again without this interference?
Thank you for your time, and help - if given.
