I am going through the document looking for broken internal links. When I find one, I want to open it for manual editing, and stop.
I have the text portion with the broken internal link in the variable thisPara. I need to select it, so that .uno:EditHyperlink will open it.
Here’s my code so far (needs the auxilliary function BuildAnchorList which can be found here)
Function isInArray( theString as String, theArray() as String)
Dim i, iStart, iStop
iStart = LBound(theArray)
iStop = UBound(theArray)
If iStart<=iStop then
For i = iStart to iStop
If theString = theArray(i) then
isInArray = True
Exit function
End if
Next
End if
isInArray = False
End function
Sub FindBrokenInternalLinks
' Find the next broken internal link
' Pseudocode:
' * generate link of anchors - *** TO DO: prefix the outline numbering for headings
' * loop, searching for internal links
' - is the internal link in the anchor list?
' * Yes: continue to next link
' * No: (broken link found)
' - select that link text - *** TO DO: cannot select it
' - open link editor so user can fix this
' - stop
' * end loop
' * display message "No bad internal links found"
Dim oDoc as Object, oFrame as Object, oDispatcher as Object
Dim oAnchors() as String ' list of all anchors in the document
Dim oParagraphs, thisPara, oTextPortions, thisPortion ' for interating through doc
Dim sMsg ' for MsgBox
oDoc = ThisComponent
oFrame = ThisComponent.CurrentController.Frame
oDispatcher = createUnoService("com.sun.star.frame.DispatchHelper")
' get all document anchors
oAnchors = BuildAnchorList()
PrintArray("Anchor list", oAnchors) ' *** DEBUG ***
' find links
oParagraphs = oDoc.Text.createEnumeration ' has all the paragraphs
Dim iLinks
Dim oViewCursor
Dim sLink
iLinks = 0 ' internal link counter
' go through all the paragraphs
While oParagraphs.hasMoreElements
thisPara = oParagraphs.nextElement
oTextPortions = thisPara.createEnumeration
' go through all the text portions in current paragraph
While oTextPortions.hasMoreElements
thisPortion = oTextPortions.nextElement
If left(thisPortion.HyperLinkURL, 1) = "#" then
' internal link found
iLinks = iLinks + 1
sLink = thisPortion.HyperLinkURL
If not isInArray(sLink, oAnchors) then
' anchor not found
' *** DEBUG: code below up to MsgBox
Dim sHas
If HasUnoInterfaces(thisPortion, "com.sun.star.text.XTextRange") then _
sHas = "yes" Else sHas = "no"
sMsg = "Bad link: [" & thisPortion.String & "] -> [" _
& thisPortion.HyperLinkURL & "] XTextRange interface? " & sHas
MsgBox (sMsg, 48, "Find broken internal link")
' *** TO DO: How do we open a _specific_ hyperlink for editing?
' Do we pass parameters to `.uno:EditHyperlink`?
' Do we move the cursor? (Except all moves I found were relative,
' e.g. `.uno:GoRight`)
' Do we use the text portion’s `.Start` and `.End` properties?
' open the current hyperlink for editing
oDispatcher.executeDispatch(oFrame, ".uno:EditHyperlink", "", 0, Array())
Exit sub
End If
End if
Wend
Wend
If iLinks then
sMsg = iLinks & " internal links found, all good"
Else
sMsg = "This document has no internal links"
End if
MsgBox (sMsg, 64, "Find broken internal link")
