Hi, I’m not sure if this is a bug so I’ll ask here first. Sample code:
Sub PrintCursorLocation (cursor As Object)
print cursor.getRangeAddress.StartColumn & ", " & cursor.getRangeAddress.StartRow
Sub CursorTest
Dim cursor As Object
cursor = ThisComponent.CurrentController.ActiveSheet.createCursor()
PrintCursorLocation(cursor)
cursor.gotoOffset(2, 2)
cursor.gotoNext()
GotoOffset doesn’t seem to be doing anything. There is no error message either. According to the Open Office developer manual, it should move the cursor to the expected cell (C3 in this case) relative to it’s current location. GotoNext and others do move it. Am I doing something wrong?
I’m using LibreOffice 4.2.1.1 release version on Windows Vista.
