how to adjust auto fill in data base
in a data base where each record is indexed automatically
Unfortunately you are missing information.
When you have signed in you are on the main page. On that page, there, in the right hand column, is a section called Resources. Please take just a minute or two to read How to use the Ask site. It’s not all encompassing but will provide basic information to ask a bit better question than you have.
There are also a few other links at the bottom of the page - FAQ & Help which are often overlooked and contain other information.
Your question as posted can only be guessed as to the meaning. Is this an auto-increment field & you wish to do something with it? Also you are missing much vital information as noted in the above links - OS, specific LO version & database being used. Please edit the question with additional info.
