My writer top ruler is all the way to the right and is not directly under my toolbars. When I open a document I have to scroll way over to move document so I can work on it.
On my other pc2 the ruler is directly under the toolbars and my documents open in the middle of the screen. A new document begins centered also.
However, when I copy a particular document from pc1 where it is to the far right, that document also opens on pc2 on far right, like this:
I open the doc, it has lots of pics so takes a while to load. First it hits screen with no toolbars, title bar etc. Next the tool bars come back and the ruler appears. Then the ruler and doc both move to the far right…
Obviously, problem is attached to this particular document, but where do I look to fix it?
Updating to latest 6.1.3.2 did not help.
I’m using ubuntu 18.04.1
How do I control where the ruler and document will be on the screen?
thanks, seekertom
