Hi!
I use LibreOffice on Linux, and I am a big user or dark/light theme switcher.
I do not have any issue about the global theme of LibreOffice which automatically switches with the system, however it is not the case for the icons.
When I switch to dark theme, since the icon-theme do not switch too, it is very difficult to see them since most of them are black on a dark background.
I know Ubuntu found a trick with the Yaru icon-theme for LibreOffice being dark with a white outline, but I’m not fond of the Yaru icons.
I’ve found two icon-themes available through two extensions that both provide a light and a dark version of the icons :
https://github.com/rizmut/libreoffice-style-breeze
idem/libreoffice-style-colibre
But I can only change them manually.
I have therefore two questions :
1. Is there a way to automatically change the icon set? I could make a script to change the icon-theme of LibreOffice when I switch to dark/light theme, but… I don’t know how to change the icon-theme other than via the LO options, so via the graphical interface. Is there a command to change this setting?
2. If you do not know or if it is not possible to change the icon-theme automatically or through the command line : maybe you can suggest me another icon theme that would have found the same trick as the Yaru icon-theme for LibreOffice?
