How to copy & paste calc data bar conditional formatting without expanding it? A solution?
Dear all,
i know there are some existing posts on this subject. Still, is there anybody who finds how to do it?
The problem: if you copy a column with a data bar conditional formatting, and you paste it as a new column, for profiting from the conditional already established on this first column, the conditional formatting condition will be extended to both columns: max bar being referring to the max of both columns. This is pretty annoying. No matter if you paste special.
A solution? Thanks.
