Define a character style with name TradeMark. In the Font tab, set Language to English from the dropdown menu. You can also change the font face if you’re using a Hebrew or Arabic one for your main text.
When you type C++ or other Western European acronym or word, give it character style TradeMark.
Notes:
- How to define a character style is left to you as an exercice if you don’t already know.
- You could as well customise built-in character style Quotation.
- I have not tested setting language to
None because I think it will only disable spellchecking without changing writing direction.
- The advantage of using a dedicated character styles becomes apparent if you decide afterwards that all your citation occurrences should instead be written italic or highlighted in red. All you need to do is modify the character style.
If this answer helped you, please accept it by clicking the check mark
to the left and, karma permitting, upvote it. If this resolves your problem, close the question, that will help other people with the same question.
