How to create a stacked column chart with two Y axes?
I have the following progressive electricity tariff (the more you consume - the more expensive it gets per each unit):
  1. first 10 kW⋅h per month - $3 per kW⋅h,
  2. next 20 kW⋅h during month (up to 30 total) - $5 per kW⋅h,
  3. everything over 30 kW⋅h per month - $7 per each kW⋅h.
(real numbers differ, this is just an example)
I’ve drawn two stacked charts:
  1. one for consumption, kW⋅h per each month
  2. other - for cost, $ per month
image description
Consumption is stacked and consists of three parts:
  1. x <= 10,
  2. 10 < x <= 30,
  3. 30 < x.
image description
Same with cost -
  1. cost of first 10 units,
  2. cost of next 20 units,
  3. cost of other units over 30 kW⋅h/month (if any).
How do I combine these charts into one, with two Y axes? I want that each month has two stacked columns: one for consumption, and one for cost. Is it possible with LibreOffice Calc?
I attach sample data sheet for you to be able to easily play with it.tariff-sample.ods
It seems it does almost the correct thing - it stacks only series that are bound to the same Y axis. But unfortunately it places the bars in front of each other, so one hides the other. Here is your sample with such a chart, where I played with series’ areas, making them transparent with hand-adjusted gradients, so that the chart is almost usable (but you still can’t mouse-select the series that is actually overlapped by a (transparent) other series)…
image description
I’d advise to file a bug report.
tdf#133988
Thank you @mikekaganski for you suggestion!
This is not perfect, but it works however! The result is quite illustrative, IMO.
Here’s what I’ve finally got:
For consumption column I’ve set the following in the Format Data Series dialog, on Transparency tab:
  • mode: gradient
  • angle: 90°
  • border: 30%
  • start value: 100%
  • end value: 0%
For cost column - all the same, except for:
  • angle: 270°
I attach the resulting sheet: 15921506065381837.ods
