This question has been asked many times over the years, and each time it seems that it gets a different answer. This is either a tribute to LibreOffice’s flexibility or a mark of its labyrinthine complexity. Some of the answers to that question given over the years are from much earlier versions of LibreOffice and the setps can no longer be followed. Or else they seem to require much greater understanding of LibreOffice’s internals than I have and so are equally not follow-able. I have tried to follow about half a dozen different answers but none of them worked for me. My installation’s version details:
Version: 7.1.3.2 / LibreOffice Community
Build ID: 10(Build:2)
CPU threads: 16; OS: Linux 5.3; UI render: default; VCL: kf5
Locale: en-GB (en_GB.UTF-8); UI: en-GB
It was installed from my distro’s repositories. As far as I know this is not a nobbled version of LibreOffice.
What I am trying to achieve is:
Appendix A title
A.1 heading
A.1.1 subheading
A.2 heading
Appendix B title
B.1 heading
B.1.1 subheading
B.2 heading
So far I have managed to get:
Appendix A title
A.1 heading
A.1.1 subheading
A.2 heading
Appendix B title
A.3 heading
A.3.1 subheading
A.4 heading
with a page break automatically inserted before the appendix heading. Also I can get all these headings and subheadings to appear in the Table of Contents. I can fix A.3 so that it is A.1 but that is a minor concern given that I cannot get it to be what it should be, which is B.1.
Having appendices with headings and subheadings is such a commonplace in technical reports that I’m disappointed that they are not already built into LibreOffice. If anyone has managed to figure out how to do numbered appendices with dependent headings and subheadings properly using a recent release of LibreOffice I would really, really be grateful if they could set out some follow-able instructions for how it is done.
In response to @ajlittoz’s request for more information:
I originally restricted my description to the appendix headings and did not mention that I use the standard/built-in headings (Heading 1, Heading 2, etc) in the main part of the document. I have changed things such as font characteristics and indentation in those standard headings but on the on the “Outline & Numbering” tab the “Numbering style” is “Chapter Number” (greyed out). The “Chapter Number” dialogue has numbering set up for each of the levels (1, 1.1, 1.1.1 etc).
My document does not use the predifined Chapter heading; the main body of the text (after cover sheets etc) starts with a Heading 1 styled heading.
As for the appendix headings I started with mimicking the configurations of the standard headings (Appendix like Heading 1, Appendix sub-heading like Heading 2, etc). When that didn’t work I searched for the right way to do it and followed all manner of ways suggested in this and other forums over the years; trying to use Tools->‘Chapter Numbering’ was one such way. I say “trying to” because it might be that I didn’t use it correctly; in any case it didn’t work for me so I moved on to try other ways of doing it.
At present (that is, how I left it when I gave up trying different things and raised this question on this forum) it is as follows (ignoring fonts and indentations etc):
The main appendix heading:
Paragraph Style:
Organiser:Style:Name: 'Appendix heading'
Organiser:Style:'Inherit from': 'Default Paragraph Style'
Organiser:Style:Category: 'Custom Styles'
'Outline & Numbering':Outline:'Outline level': 'Level 1'
'Outline & Numbering':Numbering:'Numbering style': 'Numbering ABC'
Numbering Style:
Level: 1
Numbering:Number: 'A, B, C, ...'
Numbering:'Start at': 1
Numbering:'Character style': 'Numbering Symbols'
Numbering:'Show sublevels': 1 (greyed out)
Numbering:Separator:Before: 'Appendix '
Numbering:Separator:After: '.'
The first level of appendix subheading:
Paragraph Style:
Organiser:Style:Name: 'Appendix Sub-heading 1'
Organiser:Style:'Inherit from': 'Appendix heading'
'Outline & Numbering':Outline:'Outline level': 'Level 2'
'Outline & Numbering':Numbering:'Numbering style': 'Numbering 123'
Numbering Style:
Level: 2
Numbering:Number: '1, 2, 3, ...'
Numbering:'Show sublevels': 2
The second level of appendix subheading:
Paragraph Style:
Organiser:Style:Name: 'Appendix Sub-heading 2'
Organiser:Style:'Inherit from': 'Appendix Sub-heading 1'
'Outline & Numbering':Outline:'Outline level': 'Level 3'
Numbering Style:
Level: 2
Numbering:'Show sublevels': 3
These configurations give the result shown above. Clearly this is not the right way to do it but I am at a loss as to what is the right way.
