I’m trying to automate converting a .odt document into epub, using “Page Break” as Split method.
I can do this manually from the dialog EPUB Export, etc.
However, while trying to do it from a macro (self recorded), it uses “Heading” as Split method, no matter which method I choose. The values in the macro are different and look correct and logical to me:
For “Heading” as Split method:
Array("EPUBSplitMethod",0,0,com.sun.star.beans.PropertyState.DIRECT_VALUE))
For “Page Break” as Split method:
Array("EPUBSplitMethod",0,1,com.sun.star.beans.PropertyState.DIRECT_VALUE))
When I try to convert into epub from the command line, using “–convert-to epub”, it does the conversion with “Heading” as Split method as well.
Is there a way to use “Page Break” as Split method for automated EPUB conversion? Or is there a bug somewhere?
