I copy info I need off web and try to past it in writer and all I get is squiggly lines instead of words how can I fix this
Paste as unformatted text and tell us what happens then. And next time you ask a question, try to add some relevant information. Don’t leave us guessing.
you should use Edit->Paste Unformatted Text (Ctrl+Alt+Shift+V)
I used your direction and it worked fine, but only for text. I couldn’t seem to copy and paste any pictures (images). Do you know how to get ALL the info copied (including images)?
Also, I don’t know what relevant information is necessary. If you need more info from me, please elaborate. Sorry for lack of info, I’m new at this!
for answer to our answer push yellow button “add comment”
you can copy/paste text with Paste Unformatted Text (Ctrl+Alt+Shift+V), then copy/paste any image from site one by one in to your document
