Sometime in the last few weeks, I find that my list of color palettes (looking at Calc here) has two palettes both titled “standard”. By default, every time I want to select a color, the drop-down menu opens to the first (topmost) one – unfortunately, this first one is actually blank, devoid of any colors to select. It is the second “standard” in the list (further down) which is the actual LO standard color choices that I’m trying to use. However, every time I select a color I need to find and switch to the second “standard” palette, losing me quite a bit of time on every color selection.
How can I fix this problem of having two “standard” color palettes, the default-opened one being blank? (e.g.: how to delete the blank palette, move it to the bottom, set default to the second one, etc.)
