Hey guys, got a simple question for ya!
Just wanna know how to insert a column between two others: (attachment included).
In version 5.2.3.3 you can do that with Sheet - Insert Columns.
If this answer helped you, please vote it with (here on the left). That will help other people with the same question.
I’m sorry, I posted the same time
Ciao, select the column B and right click > Insert Column left.
If my answer helped you, vote it with and with ∧ (here on the left)
To insert a new column to the left of an existing one, select this column (clicking its header), and press CONTROL and PLUS key shortcut.
If you select a row, this will insert a new row above.
Selecting a column also works by Ctrl+Space, a row by Shift+Space, multiple columns or rows by first selecting for example two cells in a row (for columns) or column (for rows) and then hitting those shortcuts. So juggling with the mouse or trackpad isn’t even needed.
Btw, for Ctrl++ (Ctrl+Plus) if +(Plus) is on the second keyboard layer above =(Equal) use Shift+Ctrl+= (Shift+Ctrl+Equal).
