When adding a caption to figure in LibreOffice 4.2.6.3, it is automatically “glued” / connected to the figure, and stays with figure. From what I understand, it is done using automatically generated text frame (containing both figure and figure caption).
This is usually a good thing. If you move the figure, its caption is also moved, and stays together. This contrast with MS Word 2007 behaviour, where figure and caption are separate, and moving figure sometimes leaves its caption in old place; you need to move it separately.
In my case, the LibreOffice document is not a final version, and is used as input for layout and publishing. Embedded figures are only visual hint. Document contains layout instructions for including images, and captions for images should be below respective layout instructions, not below respective figures.
How can I “disconnect” captions from figures in LibreOffice (the MS Word behaviour)? I want to keep automatic numbering and autoupdating references…
Asked also on http://superuser.com/q/838577/736
