hello
do I have to copypasta or can I do it with the mouse?
If you cut and paste the formula is corrected.
If you copy and paste the fine formula unchanged.
I’m sorry what? ^^;
yes if I ctrl-c, ctrl-v B3; G3 stays the same.
but is there a way with the mouse way? because copypasting I have to make more movement
I thought you were copying the data, not cells with formulas …
oh sorry. I maybe didn’t outline what I wanted to do. I wanted to swap column B with A
but that’s not really relevant since what I want is for the data to move, but not for the formula to change. fixate G3 with B3 reference.
@LeroyG actually outlined a solution
EDIT to my answer based in your last comment to the question:
- Copy data in column A
- Drag data in column B to column A, and release the mouse button while holding
Ctrl - Paste data from clipboard in column B
A bit more complicated, but you can sort both columns from Left to right (see Option tab in Sort dialog).
By what I know, you can’t drag and drop to copy/delete the source data. See LibreOffice Help on Moving Cells by Drag-and-Drop.
Maybe the simplest way is to copy and delete the original data (Ctrl+C, Del), then paste in the target range (Ctrl+V).
An option a little more complicated, and more if you need to scroll between source and target ranges: Drag the original data, and release the mouse button while holding Ctrl, and then return and delete the original content.
Tested with LibreOffice 6.4.7.2 (x86); OS: Windows 6.1.
Add Answer is reserved for solutions. If you think the answer is not satisfactory, add a comment below, or click edit (below your question) to add more information. Thanks.
Check the mark (
) to the left of the answer that solves your question.
If the answer helped you, you can mark the up arrow (
) that is on the left (to vote, you need to have karma of at least 5).
actually. I knew about ctrl-LMB but it seems I didn’t see the forest for trees.
the only thing in the way is my OCD where I want the source to move too, but oh well.
in regards to my original post: ctrl-c ctrl-v seems to not work either, in the end. I think I did ctrl-x, ctrl-shift-v
useful help link. didn’t know about alt-LMB
