I need to use Excel and Calc in parallel, continually working on spreadsheets created by the two office suites. I find that the custom styles get lost when saving in Calc.
I created and saved an xlsx document in Excel with both the MS pre-defined styles, modified pre-defined styles and custom styles.
Upon opening it in Calc, so far so good: I can see all of the styles in the Calc “Styles and Formatting”/“Custom Styles”. The Excel predefined ones, modified or otherwise, have been renamed with the prefix “Excel Built-in …”. The styles appear to work, i.e. they change text to the correct colours and previously written text formatting is preserved.
I save the file with a new name from within Calc.
When I open the new saved version in Calc all of the Custom Styles are no longer listed, nor present in “Hidden Styles”. Also, cell text that had previously had these styles has lost the backgrounds but mainly kept the font colours.
When I open the same file from step 3 in Excel the sheet opens with the Excel default predefined colours only and no trace of the modified or custom styles. The previously written text has lost its formatting as per step 4.
It seems as if the problem must lie at step 3, somehow its not saving the changes.
THE QUESTION: Have you experienced this problem and what did you do about it?
I use:
Excel 14.07116.5000 (32 bit) (part of Office Home 2010) on Windows 7
Calc on Libre Office 5.0.3.2 on Linux Mint (64 bit).
