Dear all,
For double-sided flip-up/-down documents which are bound on the top short edge, sometimes I am under space constraints and do not have the liberty to use 1" top & bottom margins. In these cases, I have to take a manual approach with several steps which can get confusing, thus prone to error and ruining the whole print.
For example, suppose a document has 1" top margin and 0.2" bottom margin. With my printer, in order to properly print it duplex short edge I have to:
- Say a prayer
- Print simplex, Odd pages only. Now I have a stack of sheets starting with page 1, then page 3, and so on.
- Reverse the stack, so the last page is on top, then second-to-last page is underneath, and so on, then page 3, then page 1 on the bottom.
- Flip the stack over on the short edge (or rotate the stack 180° then flip on the long edge).
- Put the stack back in printer’s paper tray.
- Change the page margins to 0.2" top and 1" bottom.
- Print simplex, Even pages only.
- Repeat step 2.
& check that the print came out correct.
Any way to automate more of this?
Thanks
