i hit the spacebar and it deletes all following words . how to fix it ??
Thank you. Insert key on keyboard did not work and i did not see the
overwrite at bottom of page, but must have hit it at some point, but that
fixed my problem.
Do you mean that following characters are replaced one at a time as long as you hold the space bar down? Perhaps you have set Writer in Overwrite mode, which shows on your Status Bar like this:
Click on Overwrite on the status bar, or use your keyboard’s Insert key, if it has one, to toggle between Insert and Overwrite mode.
