After installing LibreOffice, I noticed my fonts looked different despite using the same typeset. In the past, deleting MS fonts fixed the issue, but it is not even installed this time.
What should I try doing? Please advise.
Which version of LibreOffice you installed (Help | About menu)? Which Windows? Where do you see this problem of fonts - in LibreOffice, somewhere else? Are you using the same LibreOffice profile or did you clean uninstall it and install it back? Please explain more.
My version is 1:4.0.3-3 and I am running Debian Testing. My apologies for originally not including this information.
You do not mention which font is displaying problems or what the nature of the problem is. Is the problem something similar to that shown in this infinality forum thread?
FreeType / infinality
From the comment beneath this answer it appears that the problem was not the LO-supplied fonts but rather the FreeType rendering engine, and in particular the infinality patches extension. A re-install of infinality seems to have fixed the problem.
LO-supplied fonts (Original answer)
Is your problem with the Gentium or Liberation font family? LO v4.0 ships a relatively recent version of these fonts and so would seem the most likely issue, although you are using Debian from the testing repository, which I thought would be up-to-date anyway. Under Crunchbang 11 (basically Debian stable, so bear that in mind):
$ ls /usr/share/fonts/truetype/
… I have gentium/, gentium-basic/, liberation/, ttf-dejavu/, and ttf-liberation/ directories among others. The LO installed fonts are here:
$ ls /opt/libreoffice4.0/share/fonts/truetype/
… where you will notice versions of these same (or similar) fonts. The DejaVu fonts appear to the same version as shipped with LO v4.0. The Gentium and Liberations fonts however differ in that the LO ones are a more up-to-date version.
You can easily revert by moving the relevant LO-supplied font to a different location.
Ok everything is fine now. I removed fonts-liberation and re-installed infinality. Though I believe the latter was the actual fix.
Thanks for reporting back. I will update my answer.
