The directions at this post work great for decimal points. https://ask.libreoffice.org/t/how-do-i-total-a-column-of-numbers-in-writer/48000
How do I do the same for decimal separators that use commas? Or is it not possible in Writer?
You could assign the original language to the column, e.g. French (France) and it will total. Or
You could keep your existing language and use Find and Replace to find , and replace with . but untick Regular Expressions.
TotalColumnWithCommaSeparator.odt (13.9 KB)
