After recent updates, on Linux Mint 19 (updated), a document I use every morning has stopped appearing on “recent”. Is there anything I can do? (other documents appear kind of normally).
Thanks!
It doesn’t reappear even if you start it once using File -> Open?
Hmm …
- is it saved in a different format (e.g.
.docx) or anything else what it differentiates from other documents? - Have you already tried to reset your LibreOffice user profile?
No sir, it is saved as a very regular .odt file. It used to appear on the recent list until this winter.
No, I have not tried that. could it be related? Should I try it now?
Yes - test resetting your LibreOffice user profile
To reset the user profile perform:
- Start LibreOffice
- Start in Safe Mode using
Help -> Restart in Safe Modeand confirm the restart using button:Restart - Archive your profile expanding
Advanced(click on the word Advanced right aboveHelpbutton) and clickArchive User Profilebutton - Select option
Reset to factory settings - Activate
[x] Reset entire user profile - Click button
Apply Changes and Restart
Would it be possible to upload the file (it could be sufficient to just upload the file without any content/text)?
