Hi All,
Calc 6.1.2.1
Can someone point me to an example or a how to of how to automate a series of clink functions (press this, press that, enter this, click that, etc.) with Macros?
Many thanks,
-T
Hi All,
Calc 6.1.2.1
Many thanks,
-T
http://bit.ly/faithalone. No password needed, just unlock, many buttons, formula’s and simple macros. I learned much from reading questions here, and asking a few! For Blue Macro Button’s to work, or even to look at macro’s, you will need to set macro’s at Medium, in Tools/Option, LibreOffice/Security…Macro Security… Medium… (These Macro Buttons are safe) Then close the file, and reopen.
That has a lot of neat stuff in it. How do I read the contents of a cell?
I wrote myself a test:
Sub GetCellValueTest
Dim Sheet
Dim D2
Dim F5
Dim C4
Dim RtnCode As Integer
rem assign a tab (sheet)
Sheet = thiscomponent.sheets.getByName("Jump Log")
rem get the position of "$D$2"
D2 = Sheet.getCellRangeByName( "$D$2" )
rem print oCell.value, oCell.string, oCell.formula, oCell.FormulaLocal, oCell.Error
print D2.string, D2.value
rem get the position of "$F$5"
F5 = Sheet.getCellRangeByName("$F$5")
rem write D2's string value to F5's position
F5.setString( D2.string + " abc" )
rem re-get "$F$2" after is hasw been overwritten
RtnCode = MsgBox( F5.string + " ", 0, "Cell Value" )
C4 = Sheet.getCellRangeByName("$C$4")
RtnCode = MsgBox( C4.string + " ", 0, "Oh No!" )
