I’m trying to create images in Draw with layers for different languages and I would like to import them into a Writer document showing only the language needed. For example, when I set Italian language as visible and English language as invisible, once I import the Draw image, Writer still shows both languages (one over the other).
Not even exporting in png format the result does not change: all layer are shown.
I didn’t try to print the document, but I assume it would have the same issue. Is there a way to solve this problem or a workaround?
The o.s. is Windows 10 and LibreOffice is Versione: 6.2.4.2 (x64). I import my draw drawings as OLE Objects from menù Insert.
Thanks in advance,
best regards.
Gabriele
