Impress 5.0.5.2 shows "no sound" on EVERY transition despite sound being present
Using Version: 5.0.5.2, Build ID: 1:5.0.5~rc2-0ubuntu2
If you save an Impress file with sound effects on transitions, close it and then re-open it, EVERY transition displays “no sound”. Playing the slideshow demonstrates the sounds are still present despite the application indicating no sound is set.
Clearly some kind of bug?
