I am running LibreOffice 5.3.4.2 on Windows 10
When I attempt to print slides through the Impress program – they always print to the left of the page. This is for Full Slides (not handouts). I can’t find any place within the program to correct this.
Using MS PowerPoint, I can open the same file and print the full slide and it automatically is centered on the printed page.
The printer selected does not matter – even using CutePDF the same results are duplicated.
Impress: Full Slides print left justified (off centered)
PowerPoint: Full Slides print centered.
What, if anything, can be done to correct this? I would prefer to use LibreOffice Impress as my main program, but this is a significant problem.
