In calc, ONE sheet will not save- “general input/output error”. Does not effect other sheets or files.
Can you Save As to another location? Preferably a local folder.
Using windows 11, How do I get to antivirus. Using webroot.
Al: I copied and saved the whole file , It has been saved and appears in good condition. I will now delete the old file
Thank you for your help.
Art
No. Same error message
Now also in other sheets in same folder
It sounds like you don’t have Write permissions for the folder/file.
What operating system?
Can you add LibreOffice to your anti-virus Allowed list?
Please do not use the Answer or Suggest a solution field for comments that are not an answer to the original question / solution to the problem, use Comment instead, or edit your original question to provide further details. Thanks.
