In images, what happened to "description" in the right-click menu. Had important info there
Question is about images using writer. Language is english. Using Win10
[edit: added win10 + lo4 tags]
Which version do you use? The item has been removed from the context menu. But you can access this tool via menu Format, item Description…
Thanks Regina. I’m using Version: 4.4.5.2.
I found it under Format > Object > Description…
Interestingly, the context menu shows it in some files but not in others.
