I keep getting an error 2503 how can I solve this?
You didn’t say what operating system you use but let’s assume Windows.
It might be worth reading this first, General Installation Issues (Windows) - The Document Foundation Wiki
Probably, it means that LibreOffice cannot write to folders that it needs to write to. Did you disable anti virus before trying to install LibreOffice?
Add it is a Windows error, not a LibreOffice error, you could see if Microsoft can help, for example, Redirecting
Cheers, Al
Tag meta (problems with this AskLO site) replaced by common (problem common to all components).
There’s even a dedicated Documentation/HowTo/Work around Windows Error code 2503 and 2502 - The Document Foundation Wiki page, but see also these remarks.
