Installing offline help for current flatpak installation
Trying the flatpak install in Linux Mint but can’t find any way to download and install the offline help. The deb file for the same edition fails to find dependencies, so can’t be easily installed.
Revised… I appreciate the comments given. However, I have decided to switch back to a DEB installer to use the ‘Fresh’ branch of Libreoffice and to more easily add the offline Help files, so I won’t be checking in here.
Same here. I installed the flatpak version in Lubuntu, and i don’t know how to install the offline help.
Found a package. When to search then you don’t find all packages. When to start installing and using CLI autocomplete then you see all packages:
$ flatpak install flathub org.libreoffice.LibreOffice #quickly 2xTAB
org.libreoffice.LibreOffice          org.libreoffice.LibreOffice.Help     org.libreoffice.LibreOffice.Sources
org.libreoffice.LibreOffice.Debug    org.libreoffice.LibreOffice.Locale
More information:
$ flatpak remote-info flathub org.libreoffice.LibreOffice.Help
Ref: runtime/org.libreoffice.LibreOffice.Help/x86_64/stable
Arch: x86_64
Branch: stable
Collection ID: org.flathub.Stable
Date: 2020-04-16 18:25:09 +0000
Subject: Update to libreoffice-6.4.3.2 (5a34256e)
Commit: 3f12bcb0787e48e9a2afb307502274c859e6d9ea9a5c537e1b98e6f5d1b72fa3
Parent: b624b58be81ca945de9fd366561a9ba214f03bf4f09c8f4106566ce57b5273b8
Download size: 431,1 MB
Installed size: 1,4 GB
Is this still valid? The flatpak appeared to download and install correctly, but LibreOffice cannot successfully launch the help. LibreOffice points a web browser to this path:
file:///var/lib/flatpak/runtime/org.libreoffice.LibreOffice.Help/x86_64/stable/c269e6432bbc3a22b6666ca13380ead34e55e8681411edf53417fc2d37cdc9d3/files/index.html?Target=sdraw/.uno%3AHelpIndex&Language=en-US&System=UNIX&Version=7.3
but the browser throws this error:
File not found
Firefox can’t find the file at /var/lib/flatpak/runtime/org.libreoffice.LibreOffice.Help/x86_64/stable/c269e6432bbc3a22b6666ca13380ead34e55e8681411edf53417fc2d37cdc9d3/files/index.html?Target=sdraw/.uno:HelpIndex&Language=en-US&System=UNIX&Version=7.3.
    Check the file name for capitalization or other typing errors.
    Check to see if the file was moved, renamed or deleted.
If the browser is also Flatpak’d, it will likely not have permissions to reach into the sandbox of another Flatpak.
LibreOffice needs to rework this.
Are you sure?
LibreOffice/TDF usually provides sources and also installable versions for .deb or .rpm
Now a Linux-maintainer decides to put LibreOffice in flatpack. Offline help still works, if your browser is allowed to “see/access” the location.
Next maintainer (not necessary to be the same) decides to put also default browser in flatpack/snap and forbids accessing anything but your homo-folder. So the browser can no longer access offline help.
System admin (most likely you) can decide to allow access to the needed places or install a browser in classic style where it can read anything the user is allowed to…
And your idea to this is LibreOffice should fix this? Quite difficult after it was restricted in a container with limited rights.
My suggestion would be to have another version of the LibreOffice-flatpack, with integrated offline help (and maybe even another browser to show it). But that would be up to the first maintainer mentioned above…
