UPDATE: I temporarily “worked around” my issue by creating a list of corresponding “Text Under Hx” styles that were set to the appropriate indentation, and were also listed as the “Next Style” under the Organizer for the matching Heading style. Let me know if there is a better way, though…
See below:
Hello, everyone. I am trying to learn LibreOffice 7.4.3.2.
For my document’s outline, I am using a set of Heading styles that increase the indent with each level (ie., Heading 1 indents at 0.5"; Heading 2 indents at 1"; Heading 3 indents at 1.5", etc.). [Note: This outline template with styles was originally created in Microsoft Word.]
In the Organizer tab for each Heading style, I have also designated the Next Style to “Default Paragraph Style.”
After typing the Heading, I always type a paragraph underneath, using the “Default Paragraph Style.”
MY PROBLEM: Because every Heading level is indented at a different position, I must always adjust the position of the Default Paragraph Style to match that of the previous Heading… which is a huge time waster.
It would be WONDERFUL if I could configure the Default Paragraph Style to automatically adjust to the indent position of the previous Heading. Is that possible? If not, how may I request that feature?
THANK YOU for any help… much appreciated!
